DirtBound Offroad: Mojave Tire Carrier rear bumper w/Cut & Fold or Standard Caps
WebDog
Center City, MN
Over the past 11 months we have been devloping and testing our new Jeep Cherokee XJ rear tire carrier and bumper. Fully designed and built in the USA, CNC Cut and formed in house at our San Dimas, CA location. Featuring a heavy duty double sheer hinge with grease zerk fitting, with user serviceable spindle and bearings. With the highest approach angle in its class you wont have to worry about getting stuck on a rock.
Swing arm comes default on the driver side for increased visability for lane changes, optionally it is available on the passenger side.
Standard Features:
Designed for up to a 35″ tire
Three height settings, top setting allow for tilt of the tire
Adjustable bumper mounts for perfect fit
Full Unibody mounts for 16 mounting points (requires minor cutting of rear crossmember)
2″ Receiver Tube
Hidden Safety Chain holes
Two 3.5″ light holes
Integrated Gussets for the best strength
Lighted License Plate Mount
Optional Features:
Optional Hi-Lift Mount
Optional D Ring Tabs
Standard Rear with tire carrier:
http://www.dirtboundoffroad.com/jee...ire-carrier-bumper-standard-jeep-cherokee-xj/
Cut & Fold Rear with Tire Carrier:
http://www.dirtboundoffroad.com/jee...ire-carrier-bumper-cut-fold-jeep-cherokee-xj/
Re: DirtBound Offroad: Mojave Tire Carrier rear bumper w/Cut & Fold or Standard Caps
Your new carrier looks great.
From the looks of it, a right hand carrier could also be mounted for Gerry Cans and recovery gear.
Could a second carrier be added later?
If you mean dual swing outs, I'm pretty sure he has stated he has/can make a mount for the swing out on the passenger side.
I saw that he mentioned the option existed for having the carrier on the right instead of the left, but I didn't see where he confirmed that a left and right carrier could be mounted on the same bumper at the same time. It sure looks possible, but the latch mechanisms would have to play nice with each other(looks like they would).
That will be a future option to have Jerry cans on the other side with another swing out. Yes the hinge will work on ether side.
At the moment that would be a custom add on, until we release one on the site.
Thank you for your orders!
Thank you for the orders!
What are you waiting for?! Get yours now!
Let's keep it goin.. Order yours today!
Get yourself one of these hot bumpers!
More Information and Pricing: http://www.dirtboundoffroad.com/jee...ire-carrier-bumper-standard-jeep-cherokee-xj/
Non cut and fold shown below on the naxja giveaway jeep, also shown are our lower quarter armor plates.
Shown below is the cut and fold version on our shop rig.
Hey Max,
Does either one of these have under frame mounts? (As where the tow hitch would mount) And can you still bolt up the stock gas tank skid or do you have an after market one made for these bumpers?
Hey Max,
They have unibody brackets that slide into the frame rail.
http://www.dirtboundoffroad.com/docs/Cut and Fold Bracket Install.pdf
We just redesigned the latch and a few cosmetic changes last week.
Here is a couple of teaser shots. (side hardware is temporary)
NICE. I like the bends you did.
Are these still being made?
