90xj06
- Peabody, MA
I have an 88 xj and i have been having this really bad vibration and i think its coming from the rear. last year it was so bad that hitting the brakes would make it much much worse. i ended up doing a brake job in the rear with all new parts drums, shoes and all the adjusters and stuff too. and it went away.
about a month later i changed the wheel cylinders. one got seized and took some life off the shoes.
Its mostly back now. between ~63-68 mph its the worst. im going to swap out the shoes again to see if that helps. anything i should be looking at also? i quickly checked the rear drive shaft u-joints and the seem good. the front wheel ujoints might be on the way out. but i have not experienced this kind of a vibration from those before.
i do have a broken leaf spring that i will be changing before the winter.
Im not sure if anyone has one of those vibration to speed it might be this charts.
