Fergie
- Flagstaff, AZ
Okay, electrical systems are not my forte, but I can usually tackle the problems, however this one has me baffled.
Yesterday I tried to install a manual switch on my aux. fan, so I can keep it on before the temp get to high.
30 went to the battery
85 went to ground
87 went to aux fan wire(white), first near quick by fan(first try), and then collant sensor near t-stat(second try).
86 went to toggle switch
I turned everything on, and something blew, and the cab lights, CD player, offroad lights and toggle switches went out. I rechecked the relay, and found the wires were crossed, so I put the wires on the correct tabs, and tired again.
This time, the offroad lights would not come on. The fan switch would come on, and when that switch was on, the CD played and cab lights would come on.
Everything else works, as does the fan still, but I cannot get the cab lights on, the CD player on, the OR lights on, and can't get the switch for the fan to work.
WHAT THE HELL AM I DOING WRONG?!?!?
If it is any help, the power for the switchs came from the CD player.
Fergie
85 went to ground
Fergie
