I dont need all this stuff
poorboy87
Linton Indiana
Like the title states. I dont need all of it.
94ish intake complete with injectors and t/b
98ish intake with t/b
94 exhaust manifold with flex joints- has crack around flange I can weld it or you can weld it
94 regular exhaust manifold- Has been welded at collector
Cali emissions exhaust manifold set
4.0 oil pan off a 95
two engine to trans aluminum spacers
two lower flex plate covers, one has a tab ripped off.
6 blade fan- worked when pulled. has good tabs
random a/c line assembly. 94ish I believe
two hvac control heads from an xj minus blower switches
flexplate off a 94 4.0
Make me an offer on this stuff.
MJ tail lights- one has the silver border one looks wore off. $40 for the pair
MJ tail gate. Red, slight bow in it. $60
Im looking for another set of vent windows, MJ rear sliding glass, D30 non disco
If someone wants to trade. let me know what you have.
PM me
Thanks Tim
Is the six blade fan an electric fan and would it work on my 99?
I want it. I ha to break plastic on mine because I had a stuck screw (do you have a screw that held it on?).
Sure, I need to fix this before WF, the next time my wife works on a weekend, I will come down and get it.
6 blade fan- worked when pulled. has good tabs SOLD TH
PM me
Thanks Tim
Still have everything but the fan. Make me some offers. Can get pictures if needed.
$10 for the cracked flexy exhaust manifold?
94 exhaust manifold with flex joints- has crack around flange I can weld it or you can weld it - SOLD TO COLLIN
6 blade fan- worked when pulled. has good tabs - SOLD TO TH
MJ tail lights- one has the silver border one looks wore off. $40 for the pair - SOLD TO ALT
PM me
Thanks Tim
Updated... Can get pictures if needed
I also have a set of HD Engineering no lift shackle relocation brackets. New in box with all the hardware $60
