ert01
- Edmonton, Alberta
I have an 8.8 I'm working on for my XJ... I am working on the shock mounts right now and I have a couple questions about how/where to mount them.
On the stock axle, one shock is mounted in front and one in behind the axle... should I stick with that same configuration or can I put both shocks behind the axle? What are the pros/cons to each setup?
Also, I have seen some shock mounts (like the JKS one and the factory mount) that have the bolt coming straight out (perpendicular) to the axle tube, and other shock mounting brackets that run the bolt parallel to the axle. What are the pros/cons to each setup? I have some tabs already that would put the bolt parallel to the axle, but I got them for free so I wouldn't be heartbroken if I didn't use them...
Thanks!
Mark
Thanks!
Mark
