Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Red River Chapter
Red River Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
  #8446
Old December 10th, 2019, 12:17
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is online now
Re: What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Picked up my XJ from the shop today.
Sway bar/end links back on the front, redid the steering stabilizer, got an alignment.
Hasn't driven this good in years.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old December 10th, 2019, 13:37
devildog0's Avatar
devildog0 devildog0 is offline
Installed a second NMO mount on the passenger side fender. Ran Coax though the AM/FM Antenna grommet and into the center console. It will be my secondary radio install spot, for temporarily installing CBs or another HAM radio for whatever reason. Ran power off of the power seat connector under the driver's seat.
Replaced power steering reservoir cap with a new one. The seal on the old one allowed a little bit of seepage.
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old December 20th, 2019, 07:06
Get the front suspension sorted out, now my rear speakers quit working.
Guess I know what I'll be doing this weekend. Really hoping the head unit's output isn't shot.
John V.
RRC VP
Old December 20th, 2019, 13:04
Well that was an easy fix.
The head unit reset when my battery went out earlier this year. It defaults to front speakers only for bluetooth audio. Changed the settings, got my rear speakers back.
I guess the good news is my Jeep is driving so well now that I noticed the music wasn't right instead of being focused on every bump in the road and rattle from the suspension.
John V.
RRC VP
Old December 20th, 2019, 18:50
devildog0's Avatar
Went out to the garage 10 minutes early this morning and did a drain/refill on the T-case.
Old January 6th, 2020, 08:45
Added a fuse panel to connect my accessories to so I don't have a rat's nest going to the battery anymore.
Also added the ability to manually control the electric fan.
John V.
RRC VP
Old January 7th, 2020, 13:01
flagdad's Avatar
flagdad flagdad is offline
Replaced the LCAs with longer beefier ones. Also started the led headlight replacement. Just need to establish which wire to tap for the DRLs.
Old January 8th, 2020, 07:44
Got a replacement relay in the mail last night, plugged it in and I've got manual control of the electric fan! Excited that I wired this up properly and didn't burn the Jeep down. I hate electrical.
In worse news I seem to be losing coolant. The reservoir was empty last week, I filled it, and now its near empty again. No puddles. I may have the 0331 head crack. Time to start looking for a head.
John V.
RRC VP
Old January 10th, 2020, 20:03
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
The coolant and tranny fluid got mixed. The radiator let the two fluids mix.
So I got the coolant pretty well done. Will need to replace the water pump and thermostat in the spring when I have better weather and time.
For now, I've been trying to flush the tranny fluid. It was nice and brown...
So I unhooked the return line that goes to the back of the tranny, then I ran that line to a 5 gallon bucket. Then, while the vehicle is running, I pour more tranny fluid in through the dip stick tube.
I've gone through about 6 gallons of tranny fluid so far. It's much better but still a tinge of "pink" Not sure how much more of this I have to do.
Every so often I will put the jeep in each of the gears to see if that will help...
I may now go and drive a around for a short trip and come back and then drain and flush again.
Old January 11th, 2020, 04:44
xjintx xjintx is offline
DANG been around XJ's for awhile... I think it's the first time I've heard of this. Maybe has happened and owner never realized... hope you can fix!!!
Old January 11th, 2020, 15:03
R6TeXJ's Avatar
was that a reply to my post?
Old January 12th, 2020, 09:13
Got the timer circuit added to the e fan controller
Did some troubleshooting on the head. Can’t see coolant through the oil cap so that’s a good sign. Need to test the coolant next
John V.
RRC VP
Old January 12th, 2020, 09:14
Did some troubleshooting on the head. Canít see coolant through the oil cap so thatís a good sign. Need to test the coolant next
John V.
RRC VP
Old January 12th, 2020, 09:49
R6TeXJ's Avatar
Some times coolant can escape through the exhaust. Check to see if you have white smoke/vapor coming from the tailpipe.
Old January 12th, 2020, 13:26
None noticeable.
I may have just been legitimately low. Coolant level didnít drop during the test drive yesterday.
John V.
RRC VP
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Rate This Thread:
What was done to your rig today? A7XJ Arizona Chapter 1781 March 26th, 2016 21:13
In serious need of some help today. DrMoab Intermountain Chapter 16 November 30th, 2010 20:52
Tried out the TSL's today TheInstaller Jeep Picture Showcase 12 May 7th, 2007 22:16
new 37's came today!!! atowley Modified Tech Discussion 17 February 23rd, 2004 09:02
