Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
  #841
Old December 20th, 2019, 08:21
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: What are you towing with?
Originally Posted by JohnX View Post
Picked up a new tow rig.
97 Ford F800
8.3 Cummins
Eaton Fuller 9 speed
Will pull anything...and anything...and everything.
I'll post up when I'm done. Plans are 4x4 conversion, Denali interior, Raptor paint in Jeep Liquid Charcoal Gray, Stereo, and power windows/locks.
Truck has been raptored in charcoal gray outside, black grill, black floor (over a bunch of dynamat), gray headliner, black door panels with carpet trim, and has front and rear Denali seats. Heated all the way around. Cold AC. Double Din Kenwood with backup camera. Tinted the windows. Turned up from 14psi (stock) to 28psi (estimate 350hp/1100lbft). Tows a jeep like it doesn't exist.
The MAC-10 submachine gun was practically designed for housewives.
Old December 30th, 2019, 18:26
JohnX's Avatar
Sarge <3 Ben
Old February 19th, 2020, 10:30
Spodie Spodie is offline
No pics yet, but I'm brand new to this and trying to set up my bone stock XJ for flat tow behind the motorhome.
I'm curious, what tow bars are you guys using? The price range is so drastic. $1,500 for a tow bar? Ouch.
Which combo tow bar/base plate have y'all found to work the best? Pros/cons? I don't mind spending a buck or two but geez, I'm just to figure out what's the best combo.
Old February 19th, 2020, 12:35
paulhead's Avatar
paulhead paulhead is offline
I overtighten $#!t
I've been using this one for years with no problems. Added the D ring adapters cause of my bumper but you can use regular the mounts fine as long as they're mounted solid. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 D-ring mounts https://www.amazon.com/Warrior-Produ...omotive&sr=1-2
“Lead me, follow me, or get out of my way. ”
-Gen. George S. Patton Jr.
Back at step 1, bought a YJ, an XJ going under the knife....
Old February 19th, 2020, 18:40
JohnX's Avatar
Sarge <3 Ben
Pay attention to the angle of rides at...especially if you're using a lightweight truck. Flat is good, bar at a steep angle is bad.
Rate This Thread:
Flat Towing/Dolly Towing/Lockers ? 2xtreme Modified Tech Discussion 17 August 24th, 2018 16:31
Towing a pop-up Kevin O OEM Tech Discussion 10 January 12th, 2008 20:23
towing... mikeny59 Modified Tech Discussion 6 October 26th, 2006 14:21
Towing NOVAggie Non-Tech / Off Topic 11 July 18th, 2005 19:58
Towing randrews Modified Tech Discussion 5 March 19th, 2004 21:25
