Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old December 22nd, 2017, 16:42
sdspearo's Avatar
sdspearo sdspearo is offline
Fuel check valve?
I've got a 2001 Grand Cherokee 4.0L with the fuel filter/regulator mounted to the frame (cylindrical shaped with 3 ports). In addition to the fuel pump in the tank, is there also a check valve within this filter/regulator? If so, what's procedure on how to test this check valve? The part is removed and on the bench.
Thanks
'96 XJ: Locked up D44's on 35" BFG's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, 4:1 Terra blow, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old December 23rd, 2017, 10:55
sdspearo's Avatar
Re: Fuel check valve?
Well to answer my own question, yes, there is a check valve in the fuel filter/regulator.
I found out the expensive way. The jeep wasn't holding fuel pressure so after isolating the leak between the fuel rail and the tank, I assumed it was due to a leaky check valve in the fuel pump. Dropping the tank and swapping in a new pump didn't fix it...doh! Ended up swapping the filter/regulator this morning and now holds 50psi and starts right up on first crank.
To Test:
The filter/pressure regulator has 3 ports. The two on one end are the inlet from the pump and return to the tank. The one on the other end is the outlet and feeds the fuel rail. The check valve is between the fuel rail port and return port. You can test the check valve by blowing into the outlet port with your mouth while blocking the inlet with your finger. There shouldn't be any air leaking out thru the return port.
Wish I knew this before automatically assuming a bad check valve in the fuel pump.
Old December 23rd, 2017, 11:10
sdspearo's Avatar
duplicate
Old December 31st, 2017, 14:07
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
Thanks for the info, I only was aware of one in the fuel pump.
mac 'check yoself' gyvr
MWC President / President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Fuel pump check valve DrMoab OEM Tech Discussion 11 July 18th, 2013 10:40
Fuel Check Valve jeepkid03 OEM Tech Discussion 8 June 9th, 2012 06:18
BMW fuel check valve DanDXJ OEM Tech Discussion 7 May 31st, 2011 19:17
Fuel check valve heyhar Tow Rigs and Trailers 10 November 15th, 2009 10:05
Fuel check valve OILBURNER OEM Tech Discussion 7 February 5th, 2006 00:03
