heyisforhumans
- Omaha
2001 XJ Sport
The nut fell off my battery strap, it shook around and the caps came off 3 of the cells and some acid came out, voltage dropped to 9..."check gauges" light comes on.
Got a nice new battery and terminals, same problem.
I start it up (cold or hot), shows 12 V, run it for 30-60 seconds and then the voltage quickly drops down to ~9,9.5. This is consistent, every time for 2 days now.
Anyone seen this? My wiring looks good. A year ago I was just over 14v but since that time it's slowly dropped to 13.5, until a few nights ago.
I'd rather change an alternator than PCM. Doubt it's a loose wire. I'll check the alternator tomorrow. I wonder if something went bad from running on a 9v battery.
