NEw Universal Hood Louver Panels from Hyline Offroad
Hyline08
Perkasie, PA
HyLine Offroad's universal Hood Louvers Panels not only give you a customized appearance on the outside, but also help remove unwanted heat from under your hood. They offer fully functional Universal Hood Louver Panels that you can place on your Jeep wherever you like them. On the hood, on the fender, it’s your choice! You can choose to locate the heat-venting louvers in the most crucial areas of your hood or fenders to allow the largest amount of heat to be removed from your engine bay. Flush head threaded studs are already pressed into the panel for a great smooth finished look. Installation is made simple with our precision laser cut metal template. Just lay the template on your hood or fender, drill and cut holes. Hood Louver Panels come complete with smooth black semi gloss powder coat or unfinished 5052 Aluminum.
Note: A universal fit means these louver panels are not made for any one specific vehicle, but are only limited to fitment and your imagination. We do not guarantee proper fitment on all vehicles.
Also for XJ's only, we have our XJ Louver panel shown here.
[FONT=arial,helvetica,sans-serif]Description: Get that incredibly customized appearance you've been looking for. Hyline Offroad's fully functional aluminum Hood Louver Panels feature heat-venting louvers located in the most crucial areas above the engine bay. These panels are a good way to cover up cosmetic flaws on your hood and keep your engine running 10-20 degrees cooler on the trail or street. Stainless Steel Flush Head threaded studs are already pressed into the panel for a great smooth finished look. Flawless installation is made possible with our precision laser cut steel template, instead of a flimsy unreliable paper template. Everything you need to perform a professional installation is included within our kit. Hood Louver Panels come complete either unpainted 5052 Aluminum to finish as you desire or with a smooth black semi gloss highly durable powder coat finish.[/FONT]
http://www.hylineoffroad.com/product_info.php?products_id=54&osCsid=add80b4ca6a6b90bfe2149616d59e6c7
