power antenna
skipc
On an 89 Laredo, how does one get to the power antenna? I pulled the kick panel out, and there's steel between it and me. I looked behind the wheel well liner and there's steel. Same with under hood.
Does the whole fender have to come off???:looney:
As others mentioned, pulling the plastic inner fender out is your main entry. If it's real tight in there, you can pull the lower two bolts that hold the outer fender on by the rocker panel, and then another bolt between where the two door hinges attach to the body, and then pull the lower portion of the outer fender away to get more clearance.
Take off the tire first to give yourself more room.
