parting out built xj
wvredxj
wv
this is located in summersville wv
please pm me here, or email me at [email protected]
thanks for looking
here is everything that is for sale:
built 8.8, front hp d30 and np231
ford 8.8 out of 99 exploder
31 spline stock shafts
yukon 4:88 gear
full detroit locker
homeade truss
welded tubes
fairly new calipers and rotors (bought brand new when axle was installed)
M.O.R.E. spring pads, ubolts, and clamps.
front hp non disco d30
tnt truss with built in uca mounts
brand new alloy usa cromo 27 spline shafts
alloy usa inner axle seals
moog balljoints, new wheelbearings
precesion 4:88 r/p with lockrite (hardened pins, crossshaft, and carrier also installed)
good pads, calipers, and rotors
1000 bucks.
NP 231
new chain put in 6 months ago
Advance Adapters SYE
the rear 8.8 had some bites, but i will just post a price a make it easier.
1100 takes this thing home. it stands up to heavy abuse and is ready to bolt into your xj/yj with no shims, ready to bolt your driveshaft in.
the np231 is also still for sale, i will be removing that this week. no leaks, works fine, shifts easily into low lock and 4wd. No noises. I will also include rear tom woods double carden driveshaft. 400 takes this thing home.
offroad bumpers
here they are, lots of you guys have been wanting them, so i will put them up, first come first serve.
front jcr winch bumper. Added front hoop. Herculined, and added reinforcements. bent it the first time, sent it back, they added reinforcements, then i added more, couldnt bend it again, this thing is tuff. 2 nice big d ring mounts, and side protection. Some of the paint is peeling. You will have well over 550 to make yours look like mine from jcr. i will take 400.
link to front bumper:
http://www.jcroffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=2XJFWN&Category_Code=XJB
pics of bumper on jeep:
http://img.photobucket.com/albums/v513/bigwhitehd/wheelin/cracker8.jpg
rear hidden hitch for cherokee. Ran this thing for a long time. seen some abuse, lots of scratches, a little surface rust, and one chain slot is bent up slightly. will let this thing go with no hardwear (bolts broke in bolt stripe) for 40 bucks.
the bumpers include all hardware.
beadlocks, 35 inch baja claws, and black rock krawler wheels
crager 32 bolt beadlocks, screw in bolts, 15x8, 5x4.5. scratched, all bolts are included, nice wheels....400
35-50% tread, no wobbles, or shakes. i run these things with no weight. they are loud, but do ride good.
i will let these go for 400
4 15x10 ar black d ring rims...lots of scratches 60 bucks takes them home.....or for 430 you can have both of them, ready to bolt onto your jeep.
NO WARRENTIES ARE IMPLIED OR STATED
here are some pics:
front bumper:
added reinforcement:
rear 8.8:
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00110.jpg
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00109.jpg
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00108.jpg
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00106.jpg
front dana 30:
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00125.jpg
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00121.jpg
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00120-1.jpg
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00119-1.jpg
np 231:
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00114-1.jpg
http://img.photobucket.com/albums/v513/bigwhitehd/miscellaneous/DSC00111-1.jpg
Jamesss said:
Do you happen to have the stock left rear bumper ends (pepper red) from that jeep?
no
the beadlocks, 15x10's, front end, tcase and front bumper are either sold or pending
the rest is still foo sale.
bump
front end and rear end still for sale
and the claws are still for sale, 350 pick up only.
