99 4.0 Excessive Cranking - Hard Starts
jerms234
Utah
Hi all,
Recently the XJ has developed a new issue. Usually it will fire with 1 second of cranking or so, and likely no more than 2 revs of the motor. Recently, cranking is taking 10-14 seconds when the jeep has sat for more than an hour.
If it is shut down and restarted quickly, it will start normally and quickly.
Suspect fuel is draining back to the tank from the rail, which I suppose means leaking injectors? Isn't there also a check valve in the pump? Do I need a fuel pump and injectors? Which would you recommend I try first?
Thanks,
99 XJ 4.0 AW4 NP 231.
When a 1997 to 2001 Cherokee won’t start on the first try day after day, the first thing to suspect is a failed check valve on the fuel pump. The fuel pump check valve is supposed to hold pressure in the fuel line while the engine is off. The check valve is located on the fuel pump and located in the gas tank. A failed check valve allows the fuel to drain back to the tank. This results in one or more of the following symptoms:
SYMPTOMS
• Longer than normal cranking times
• Never starts on first try, almost always starts on the second try
• Rough idle for a few moments of idling
• Rough running for first ½ block of driving
• Little or no fuel pressure at the fuel rail test valve similar to this -
1- Key in on position; fuel pump primes for 2 seconds then stops. 0 PSI
2- Cranking over the engine. 2-3 PSI
3- Engine starts and idles for 20 seconds. < 5 PSI
4- Engine idles and fuel pressure creeps up to 45-50 PSI.
POSSIBLE CAUSES
• Failed check valve on the fuel pump in the gas tank.
• Leaky fuel injector(s) may be the true cause of your problem, but more likely they are simply contributing to the check valve issue.
Testing of the fuel injectors should show if any are faulty and are allowing fuel to drain into the cylinder. Either problem can allow heat soak to vaporize the remaining fuel in the fuel rail, and you may be dealing with a bit of vapor lock as well, especially in warmer weather.
1. Connect the gauge at the fuel rail and start the engine. The gage should read 49 psi plus or minus 5 psi.
2. Turn the engine off and immediately clamp the fuel line just ahead of the fuel tank. Watch the pressure gage and see how long it takes to loose pressure.
If the pressure remains at 49 psi for an extended period of time then the problem is in the tank - probably the check valve. If the pressure falls below 49 psi fairly rapidly then the problem is probably one or more leaky injectors.
There are a few solutions to the problem –
1. Turn the key to ON for 5 seconds and let the fuel pump prime. Turn the key to OFF, turn the key back to ON for 5 seconds, start the engine.
2. Crank the engine for 3-5 seconds, pause, and crank the engine again. It will almost always start on the second try.
3. Replace the fuel pump assembly in the gas tank. The check valve is not a separate part and cannot be serviced. This is both expensive and time consuming because you have to remove any hitches and skid plates and then remove the gas tank from the vehicle.
You can use solutions 1 or 2 for as long as you want to, they do not harm anything and the fuel pump will continue to function for many more years.
If you do replace the fuel pump assembly, purchase a high quality OEM style pump assembly such as Bosch or Carter. Some cheap aftermarket fuel pump assemblies, like Airtex, and Precision don’t hold up and fail completely within 12-18 months.
Thanks for the detailed reply that helps a lot and exactly describes my conditions. I think I've heard of people installing a check valve in the rubber line from the tank to the frame? Any body have suggestions on what part to get for this?
Thanks,
The older ones may have rubber lines, 97 & up are the hard plastic variety. Not exactly the thing you cut and splice into it with a check valve in the Auto Zone parking lot.
