They are probably 15 years old, Rubicon Express, not adjustable. Uppers have rubber bushes, lower have superflex bushes on axle, rubber bushes on the frame ends. I rebushed the rubber ends when I bought the jeep just over a year ago. The rubber was shot. In hind sight I should have converted them to superflex on all ends. The 15 year old superflex joints showed almost zero wear, the rubber bushes where torn, disintegrated.
Also the uppers should be adjustable, ( adjustable may not have been available back 15 years ago) as I just about maxed out the adjustment on the body mount slots to get the caster right. With wrong caster, the truck drove horrible, now all is nice. but next time, when these rubber bushes fail, I will switch to superflex there, and adjustable uppers.
I installed Rock Hard brand bolt on lower axle mount skid plates, which have saved them more than once from damage. Prior owner did not have these, and I had to fix mount damage do to that.
https://www.rockhard4x4.com/product_p/rh-9030.htm
