RE 7.5" Coils - First Impression
Nay
Colorado
I replaced my RE ZJ 4.5" coils (XJ 5.5") with the TJ/XJ 7.5" coils this weekend. My goal was to increase spring rate a little bit for better handling, and to replace the 1" of spacer on top of the ZJ coils and add about a half inch of lift. In a previous thread, we didn't resolve the question of whether the ZJ coils have a 240 spring rate and the 7.5" a 250 spring rate...or whether both are 200. I don't know, so I'll pass on my observations, which suggest the 7.5" are a bit stiffer.
First and foremost, I think these are truly 7.5" TJ coils, and as such give a bit less than 2" more lift than the ZJ coils on an XJ. I was running a 3/4" poly spacer plus a 10mm (3/8") OME poly spacer on top of the ZJ coils. I left the OME spacer in and just removed the 3/4" spacer. From this I gained about 3/4" of total lift. Exactly what I wanted, but this suggests that the 7.5" coils are 1.5" over the 4.5" ZJ, not 2". I'd have been pissed if I'd taken out the OME spacers, because I would have wanted them back in.
As for spring rate...the handling has definitely, markedly improved. With 8" of lift and no swaybars, I can take the twisties with hardly any lean. It is excellent. And there is one other thing that I have suspected for a long time: RE coils are not the exact same side to side.
Whether this is in the design spec, RE's coil manufacturer is doing the proper design and not telling them, or just the occasional production "error", I don't know. But this is my second set with this "advantage". Maybe it is because the XJ D30 coil pads are different side to side in how the coil is rotated and seated...maybe the pigtail difference is designed to ensure proper seating on the coil tower? Maybe I am imagining things? :dunno:
Anyway, if you draw a straight line on a piece of paper and line up the bottom edge of both coils parallel to this line, you will see that the "pigtail" on top of one coil is about 1/2" longer than the other. This coil should go on the passenger side. When installed this way, I find that my XJ loses the tendency to lean more to the right with road crown, and that it stops pulling to the right. I experienced this same thing with my first set of ZJ coils, but not with my second set of ZJ coils.
I don't know the deal here, but man it makes a difference because my front end is balanced side to side.
Anyway, I highly recommend these coils for an 8" lift. They definitely beat adding spacers to the shorter coils.
Nay
Mine just arrived, should be waiting for me tonight, which is good since I NEED to finish the front suspension this weekend to have any hope of wheeling by the end of the month!
Good news on the spring rate!
CRASH
I just installed an 1 3/4" poly spacer on top of mine. Now they give me the 8"
of lift I was after in the first place.
I think my springs are different than they claim to have shipped. They feel softer by far than the ZJ coils that were in here before.
Live and learn I guess. When you buy from RE it is going to be a crap shoot if you get what you pay for.
The 1 3/4" poly spacer makes my XJ close to level with Rusty's 6" rear pack and a 1.5" lift shackle out back.? Go figure that.
I tried calling RE 5 times and was transfered to a "mail box" every time.
No customer service at all.
I will never buy from them again.
my .02 on RE
i have the 7.5 coils up front and 4.5 leafs, 1.5 block, and 1.5 shackles. i run a BPI front bumper and winch and carry a spare and aftermarket bumper in the rear. looks like a hot rod! swapped in a .75 spacer, and its still a hot rod! i'm just hoping the rear will level out eventually?
brandon
The 4.5" leafs will give you 5.5" without a lot of extra weight back there. With a 1.5" shackle and 1.5" block, you are probably 8.5" in the rear and 7" up front (7 3/4" with the spacer). Go to a half inch block and call it a day.
Nay
