NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
You can as long as you have it hooked to a large enough tank.
I get 120psi (limited to 120 psi) out of my stock pump (89). With a 5 gallon tank it would run air tools for short periods. Do not expect mega torque out of them though. You need a lot of volume for more torque.
The Sanden compressor is capable of approximately 10 cfm @ 350 psi.... Using the Sanden air conditioning compressor as a source of OBA; you will need to install an air regulator and storage tank...... Most air tools draw 5-10 cfm @ 90 psi and depending upon the tool.... some draw more....
Contact [email protected] ..... He has already done this installation.
