01xj
- Live Free or Die
I read this on a recent post (from Judd):
"ff....the cycling of the fan when it rains is because you probably
have it on Defrost?? Is supposed to cycle the A/C compressor
and therefore the elec fan. Does a much better job of removing
fog from the windshield using the A/C to help remove moisture
from the air. If not, you do have a water infiltration problem
either under the dash, or really, located at any relay having to
do with the A/C or fan operation."
Does this mean that at every ventilation control setting on the
console (other then the off position) the A/C compressor will
cycle. I've been wondering why I get that cycling sound even
when the A/C is not on. Thought I had a potential problem,
sounds like I don't.
Any experiences with this?
