buffalomatt350
- Manchester, MI
I have a 96 XJ that has started making a terrible screeching noise coming from the front (maybe the drivers side) while driving. It is only while the vehicle is in motion, and sounds like a dry bearing noise. I found a failed axleshaft u-joint on the driver's side and replaced that, thinking that that was the cause, but the Jeep still makes the noise. While I had the axleshaft and hub out, I checked the wheel bearing and it was smooth and not sloppy. It is noticeably worse tonight and it is raining. I can't think of anything else that could be making this noise... The front driveshaft u-joints are all solid, no slop there, and I did not feel any slop in the front differential yoke either, so I don't think that that's our problem. Any ideas would be appreciated.
I should also add that the noise occurs when driving straight or turning, but is usually guaranteed to squeel when turning.
Thanks,
Matt
Thanks,
Matt
