DonkRado
- Charlottesville, VA
Ok, so I've figured out that the XJ I just bought has a pretty severe exhaust leak into the cabin. Take a look:
So, I found a couple of holes in the floor pan. One is dead above the muffler:
The other is basically right above the tailpipe:
I also found what seems to be a pretty big leak at the flange gasket. There's no question that driving the car around will make you lightheaded, and help you feel good and stupid for an hour or so after riding.
Unfortunately, I have to take this thing on a 4 hour trip to Christmas with the family this weekend. Of course, it's another 4 hours driving back.
I've recently learned that the shell itself isn't much worth saving from rust, but I've got to get this problem patched up immediately. I am going to get some sheet metal (probably 18ga) and seal up the holes that I've found. I'm also going to tear out the rest of the carpet to find any others.
What should I use in conjunction with the sheet metal to get a good seal to the pan? Will a high temp RTV sealant work well to keep exhaust fumes out? Anything better? I think I'll probably be 'painting' over the whole job with Herculiner or at least a spray in rubberized coating, but I want to try and seal the metal down at the mating surface, too. I don't have access to a welder of any sort right now, so I'll be riveting the panels down. Maybe following up with a few sheet metal screws. Any other suggestions? I understand that this is an extremely dangerous situation, and I plan to seal these holes up thoroughly.
Also, I also realize that this is just a temporary fix and will likely have to be redone down the road.
Also, I suspect that I'll have to cut the exhaust flange bolts out of place and drop new ones in. Can anyone confirm size on those? I've got 3/8'-16 from my searching.
Lastly, has anyone else had any experience with this? Any other places I should look? Could the exhaust be possibly entering through the HVAC system if I have some bad vacuum lines and the leaking flange gasket? Maybe it could come through the shifter assembly? Thank you for any help. My dog and I both appreciate it.
