Old August 26th, 2007, 11:53
bigbadwolf54's Avatar
bigbadwolf54 bigbadwolf54 is offline
Will not stay running (not normal running issue)
My 91 xj (has a 99 motor in it) wont stay running as the title says. It starts up maybe every 5th time or so. When it does start it might run for 2 seconds or 15 minutes, but then will die whenever i hit a turn signal or roll down a window. I just put a Exide Orbital battery in it. When I put the battery in I hooked up my winch at the same time. I tried the main body ground and I had to put a new starter in it anyway so i know it isnt shorting out there. The day after I put the battery in for some reason the relays for the power locks blew. Does anyone have any idea of what this could be?
Thanks,
Ben
Old August 26th, 2007, 12:05
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: Will not stay running (not normal running issue)
A short! Somewhere! It's obviously in the ignition circuit! Just start testing wires! Check continuity to ground all your wires and make sure ground is SUPPOSED to be there.
Old August 26th, 2007, 12:07
ok i hadnt thought of that. you know how when u get pissed aty something you dont think right? thats how it is right now. but why would the power lock relay blow?
Old August 26th, 2007, 12:12
Lowrange2's Avatar
Member# 2368
Not sure about the door lock relays... It takes a dead short to blow a relay tho... they are pretty tough. Go by the parts store and pick up a chiltons or haynes manual. The door lock relay wiring diagram is on page 12-26 i think.
Old August 26th, 2007, 12:30
i hvae both fsm and the clintons and hyanes. Do you think it could be the door wiring that is messing everything else up? My doors have been made removable.
Old August 26th, 2007, 13:07
Lowrange2's Avatar
Member# 2368
Oh wow i would def take a look at all that wiring? That could def uck up the door lock relays.
Need Help... Will not stay running? CrashSomers Arizona Chapter 16 May 24th, 2007 14:28
XJ won't stay running jpk Jeep Street and Performance 3 May 13th, 2007 19:53
Won't stay running Tonka12 OEM Tech Discussion 5 January 12th, 2007 13:45
Running just above 210 normal? ABN146 OEM Tech Discussion 10 July 26th, 2006 19:36
ZJ Won't stay running Hawaiian Style Tow Rigs and Trailers 3 July 13th, 2004 15:09
