Old October 16th, 2019, 11:57
Rockwood Rockwood is offline
Re: Piecing together kit for 3"- 3.5" lift on 33's
Squats IT. Damned no edit.
Old October 24th, 2019, 12:36
Scrubber3 Scrubber3 is offline
Lower control arms for the front. Caster is important! They don't even have to be adjustable, just extended for ~3 to 4 inch lift. YJ brake lines for the front. Extended bump stops front and rear.
If you are going up in tire size you'll need to re-gear. Your transmission will thank you.
Old October 24th, 2019, 13:11
jimbar's Avatar
jimbar jimbar is offline
IMO you should call Dirk at https://dpgoffroad.com/
He's the man on what really works best for the XJ. Oh, and gearing should be on your list as well. Just say'n
Old October 24th, 2019, 14:47
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Become a RED member and have editing rights.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 24th, 2019, 14:55
lazyxj's Avatar
NAXJA Member #1310
Washington State has dozens of steep upgrades, 33"s and 3.55 gearing is going to be lugging much of the time, it should have 4.56 gears.
Might consider upgrading the brakes too. Taller and much heavier tires need more brake to stop them safely and in the same distance as when stock, you can't fight the laws of physics.
Old October 30th, 2019, 16:40
33s with 4.88s are more fun though. And allows for larger tire size later. Just saying.
Old October 31st, 2019, 13:25
denverd1's Avatar
denverd1 denverd1 is offline
YAAAASSSS
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
WTB 16" tires or 15" steeples 4"bump stops 3.5" lift brake lines Seeker SoCal For Sale 7 February 19th, 2014 14:57
Piecing together a 2" lift... GFAndoscia Modified Tech Discussion 6 December 11th, 2011 17:21
complete 3" lift kit with full leaf packs, RE 4.5" coils, (2) 2" coil spacers xDUMPTRUCKx For Sale: Private Party Only. XJ ITEMS ONLY 25 July 5th, 2006 12:33
full spring pack 3" lift, RE 4.5" coils, (2) 2" coil spacers xDUMPTRUCKx SoCal For Sale 1 June 20th, 2006 16:23
Piecing together 3" lift ecrogers Wanted: Private Party Only 2 November 22nd, 2004 08:45
