Old June 23rd, 2019, 19:18
Tonyt22 Tonyt22 is offline
Liberty shafts in a xj 8.25
I've been searching and getting conflicting answer with axle shafts fit in a xj 8.25 I know the carrier will but what about shafts thanks
Old June 23rd, 2019, 21:32
RCP Phx RCP Phx is offline
Re: Liberty shafts in a xj 8.25
They should fit,what are you doing?What year XJ and what year Liberty?
Old June 24th, 2019, 20:06
My xj is a 93 so converting over to 29 spline axle shafts with carrier and any liberty I can find
Old June 24th, 2019, 20:24
If your going to pull Liberty shafts then grab the disc brakes also!!!
Old June 25th, 2019, 00:57
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
He'll for all that go pull a liberty 8.25, screw the shafts. Your going to upgrade a carrier and all this, I would've done this long ago had I known different!
Old June 25th, 2019, 02:04
I believe they are different the liberty is coils and xj leafs not worth the fab work
Old June 25th, 2019, 02:05
Almost forgot about those
Old June 25th, 2019, 03:09
True, just thought less work for you. I believe the shafts are the same, I just pulled some out to get brakes last week.
Either way you've got. Options!
Old June 25th, 2019, 20:38
The local junk yard is having 40% off sale 4th of July weekend so I'll pick up the carrier and maybe 2 sets of shafts that weekend debating if I should spend the extra time and try to hunt down a lsd carrier or just get the open and get a locker later down the road
Old June 26th, 2019, 09:16
two_door_rob two_door_rob is online now
Has anyone here actually put KJ shafts in an XJ? Quick Google search is giving me conflicting info on wether they are compatible or not. No personal experience here, would just hate to see OP buy a bunch of stuff that doesn't fit. I have 8.25 shafts in my shed if you want some measurements off them
Old June 26th, 2019, 14:26
https://www.yukongear.com/diffdetail...252797-%252704
Old June 26th, 2019, 22:01
chickenbot chickenbot is offline
For my 93 I just grabbed a kj carrier with the disc brake parts and put them into a newer xj with 29 spline shafts
Old June 27th, 2019, 14:48
I was getting the same info I believe I looked at some Yukon shafts or something and under fitment it included 02-04 kjs so I think if I get one from there I'll be good
Old June 27th, 2019, 14:50
So I was looking at the new carrier for the d30 and had a old cross pin laying around from when I installed my locker and it's way short like flush on one side and about a inch short on the other does the 3.73 and up carriers take a different cross pin or do you think Amazon sent me the wrong one ?
Old October 2nd, 2019, 08:50
Just to clear everything up in case someone runs into this thread from a google search after cross referencing with part numbers from autozone shafts for the xj and kj they are indeed different. kj shafts are just slightly longer at 30 1/4 and xjs at 29 inches that's from base to end of shaft not total length
Alloy USA pre omix D44 rear shafts and d30 stock shafts Trouble SoCal For Sale 4 March 22nd, 2017 11:55
HP44- 5.38's, Detroit Truetrac, Alloy shafts, nitro shafts chpmnsws6 MWC For Sale/Wanted Forum 16 March 4th, 2014 06:35
D35 shafts and D30 shafts for vacuum disco axle Brandoson Arizona For Sale/Wanted 7 August 23rd, 2009 02:47
superior 8.25 shafts vs. alloy usa 8.25 shafts. 29 splines of course xjwest Modified Tech Discussion 5 April 25th, 2008 18:59
8.25 shafts&spiders/30 shafts, rustys panhard brace shmoken875 NAC Classifieds 1 July 20th, 2007 12:31
