Old August 16th, 2015, 22:41
muddeprived muddeprived is offline
How low can you go with RC long arms?
Anyone go lower than 4.5" on RC's long arms?
I have the choice of selling my xj for a more fuel efficient means of transportation OR modify it so it suits my needs and that basically means lowering it as low as I can and running smaller tires.
How low do you think I could go with RC's radius arms?
Old August 16th, 2015, 22:53
two_door_rob two_door_rob is offline
Re: How low can you go with RC long arms?
Im running them with 3'' of lift and 31's, ive been running this setup for about 6 months now with zero issues.
Old August 16th, 2015, 23:00
Thank you! Just what I needed to hear. Do the arms come close to hitting the frame on uptravel?
What springs (f&R) did you go with? I'm thinking OME springs with a spacer and their own AAL if needed. That's the first lift I put on my xj years ago and it was a dream to drive.
Old August 16th, 2015, 23:26
I'm running Rustys 3" HD coils and OME 3.5 leafs with no lift shackle relocators. I haven't checked to see how close the arms come to the frame at full flex, but I do know they clear.
Long arm fitment questions using RE Long arms Nugget Modified Tech Discussion 4 April 5th, 2015 21:07
Long arms vs mid arms rkates Modified Tech Discussion 11 December 6th, 2012 17:08
ford 44 radius arms to long arms need ideas BigRedMachine Modified Tech Discussion 2 January 23rd, 2008 19:45
Short arms, vs. long arms, vs. RE drop drackets Toyman Modified Tech Discussion 20 February 15th, 2006 02:49
Long arms and upper control arms. Dann Modified Tech Discussion 22 September 7th, 2003 13:17
