Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old December 15th, 2017, 04:37
xjintx xjintx is offline
Flat tow... lights
Searched but can't locate an answer I flat tow my 2000 Cherokee behind my F250 that has slide-in camper. I am being "Told" that I can get a wiring harness that is plug and play. Currently I have Harbor Freight magnet mount lights for brakes and turn signal on towed Jeep. Just plugs into trailer plug on Truck. Works fine but I sometimes forget to put them on and even to take them off the Jeep.
Anybody know about a plug and play that allows me to just use the XJ's lights?
Thanks...
Old December 19th, 2017, 09:41
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Re: Flat tow... lights
This isn't 100 percent plug 'n play, but it doesn't look terribly complicated to install and may meet your needs.
https://www.etrailer.com/tbwiring-20...p_Cherokee.htm
Old December 20th, 2017, 18:39
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
This is what I did for towing lights.
https://www.flickr.com/photos/lwade/...7603323570942/
There have worked well for the last 14 years and 85,000 miles of flat towing.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old January 12th, 2018, 08:58
bwinter1946 bwinter1946 is offline
I have the Roadmaster Diode towing kit on my 99 Cherokee. So far no issues. When you are done there is no feedback to existing wiring and no extra lights to hook up.
Old February 2nd, 2018, 22:43
dktool dktool is offline
I just finished doing a diode job on my '98, purchased a 20 pack of 15 amp diodes for $6.00 and got busy.
I pulled a 16/3 s.o cord from the engine bay along the right inside to the right rear T/L area the ran a span across to the left side light.
I used a total of 13 diodes, 9 would have made due but I wanted to have both the brake and turn lights on the Heep to come on together when the brake / turn on the tow vehicle was activated. (4 wire from tow vehicle)
Took about 4 hours to complete with so interruption breaks, total cost $6.00, already have the cord and front connector in my electrical collection.
Old February 3rd, 2018, 05:02
DKtool... that sounds like a nice setup but don't understand how you use / mount just diodes? I'd love more explanation or pictures. Is it activated by the trailer connector on tow vehicle?
Old February 3rd, 2018, 10:45
Spliced in the diodes as needed in the leads between the taillights and their plug in connection behind the rear side panels. All additions made inside the vehicle.
I miss-spoke previously regarding diode quantity, I used a total of 11
I can draw up a schematic and post it here when I have time, as of now it's filed away in my head.
Old February 3rd, 2018, 12:23
I purged my head, here's a schematic;
Old February 3rd, 2018, 16:04
scottmcneal's Avatar
scottmcneal scottmcneal is offline
The 97 Club
Don't know if you want to buy one but this is the lace i have bought all of mine. i have had 3 different saturns that has been towed behind my motorhome.
Hope this helps
Smiley face added so people won't feel but t hurt.
Don't make old people mad.We don't like being old in the first place, so it doesn't take much to piss us off.
RIP Shady, the Greatest Father & man i will ever know.
Old January 9th, 2019, 05:56
Warrior26 Warrior26 is offline
Hope this helps
Was it hard to install?
Old January 11th, 2019, 16:37
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
It's not overly complicated on an xj, the tow bar mount uses the same holes as the factory tow hooks. Might have to pull the bumper, dont recall. The wires just get run from front to back, simple.
The MAC-10 submachine gun was practically designed for housewives.
Old January 12th, 2019, 23:35
lazyxj's Avatar
NAXJA Member #1310
As an alternative to utilizing the existing XJ tail lights, connected through diodes, is to add an extra set of bulbs in each housing and eliminate any cross connection.
Eliminating the diodes also raises the voltage that the tail lights see.
I drilled a hole in each tail light housing and used a snap in tail light socket, A fresh set of four-wire cable was run from the tail lights to the front bumper where a 7-pin plug is located.
I used this tail light kit. The bulbs has since been upgraded to LEDs.
https://www.rvupgradestore.com/Bulb-...9-p/bx8869.htm
https://www.flickr.com/photos/lwade/...h/46669859632/
Old January 16th, 2019, 19:03
JohnX's Avatar
Sarge <3 Ben
That's a nice setup.
I made some mag mount lights back in the flat tow days because I had a couple different xjs to tow...but that extra bulb deal is slick.
Rate This Thread:
high idle caused my dash lights/tail lights to go out?? wgregt OEM Tech Discussion 55 December 16th, 2012 18:16
No marker lights, no brake lights, no dash lights twodoorXJ OEM Tech Discussion 5 December 16th, 2012 08:35
XJ flat flares, AFE cold air intake, tail lights, spacers, etc.... turbobrick Sierra Chapter For Sale 8 October 10th, 2012 19:27
Tail lights, Turning lights and Shifter lights STAY ON JSwamper OEM Tech Discussion 22 October 4th, 2011 17:20
Flat Towing and car lights question XJ Eric Tow Rigs and Trailers 10 January 25th, 2010 09:05
