2000 Jeep Cherokee
DubbyDoo
va
2000 Jeep Cherokee 4DR
4.0 Auto 4x4 189K
Cd player,ABS,AC,Power everything(Lock switch doesnt work but I have verified the motors are good)
New Tires
New Rear Brakes
New Upper Radiator Hose
New Inspection 12/13
Newer Battery
Fresh Oil Change
Coolant Flush and Refill
Serviced Ac System
Located in Chester,Va
2600$
Ugh, if you still have this in like 2 months or so, assuming I get this job in Norfolk and I move down there, I would gladly buy it. I am in love with Patriot Blue.
I might have to consider it as a rig to swap some lift parts onto.
I've got some classic parts cars to move first....but if they sell quick, I'll have to PM. In the mean time can you tell us:
which rear diff. (still forget, but I think ABS means it isn't a C8.25)
Was this yours or you flipping it (looking for known history).
If you don't already, can you get some pics of the underside and post them up so I can see how clean it is underneath?
Could you also get pics of the spots on the roof, etc? I'm still interested, but if there's rust that will spread anywhere I have to pass. Obviously I'm not concerned about axles, the engine block, springs, etc. I'm only worried about the body. Frame rails, floors, door jams, rocker panels, window corners etc.
