Folks, I’ve run into a problem. In the process of swapping a larger BBK TB in, I was attempting to remove the sensors from the stock throttle body. I was able to remove two of them, but the third (TPS) is STUCK. I cannot get the damn torx screws to come out. I’ve snapped three bits including two impact bits. The local autozone has the TPS in stock but my worry is it won’t come with screws. So, my question is, what screws will work in this position? Anything I can easily source from autozone or Home Depot? Need to get this thing running today.
My second question is can you folks help me ID which sensors the other two are? From my understanding one is the MAP sensor and the other is the IAC? Is that correct? Which one is which?
