Transfer case Bezel replacement
ve6nn
How do I get the new bezel on. Have to remove the transfer case lever. Can anyone tell me how they did it? The old one was broken so it just poped out but the new one won't fit over the handle. 96 model year 321 case
I thought all of the bezels just slid out over the lever. Since yours doesn't, you'll have to remove the lever.
Look at the base of the lever, ther is a clip that holds the lever in place. Remove the clip and then you can pull the lever out.
Are you talking about the rubber grip on the lever? I doubt that it'll come off.
Pulling the spring clip will only take a few seconds and would be much easier. Might take a few minutes to get the spring clip lined up and back in though.
