*Weekend Performance Upgrades*
cpolish24
Arizona
I Wanted to post up my Saterday morning performance upgrades on my 96 XJ
-New Performance TiG Exhaust Manifold\
-Helix Throtle Body Spacer
-MSD 8.5 Ignition Wires
-Accel Ignition Coil
-Mopar 02 Sensor
-I started with the manifold
Old cracked manifold-
New Preformance Manifold-
Install-
-Then I moved to the Helix throtle body spacer
-After that I moved to the MSD Ignition Wires and the Accel Coil
Stock wires and coil-
New wires and coil-
-Last I installed the o2 sensor.
It runs great!! :clap:
Keep your old coil handy, I had an Accel coil on my 96 and Afew people said beware and I said naw its a good unit, a year later it left me stranded
Yep! I've heard that to, thats why I keep it in my tool box in the back of the XJ. But thanks anyways!
i like that manifold, good idea with the flex fittings. if i can find another APN ill be putting a flex fitting in the down pipe to reduce stress on the exhaust
Yeah that Accel let me down as well @ the year mark. I got screwed on a blown Jacob's years ago, so I guess all I have left to try out is the MSD.
I didn't think Jeeps had PCV valves, rather CCV lines.
You are right, but that way everyone understands what I was replacing, Mine fell apart!, and the rubber gromit that seals it is oil soaked and deterialted (it also has a small crack in the top).
