rebuilt 4.0 motor(last year) new valve cover/ gasket, timing gear/ chain,basically every seal in the engine is new last april
rebuilt np231 with porc SYE
5.5" lift all mix matched
RK Long arms, 5.5" Rustys springs and HD Track Bar, Full spring pack in the rear with 6deg shims.. 7" front shocks for extra droop, 23" ss front brake lines
Homemade front bumper with a smittybuilt xcr8 winch tied into a front receiver
smittybuilt rear bumper
homemade sliders
rustys t-case skid
gorilla 2.5k suck down winch on the front
The whole top of the unibody rail has 1/8" steel welded to it solid, little to no unibody flex now
Motor driven OBA setup. Tanks not included
Reinforced steering brackets welded in, with a rugged ridge steering setup
Dana 30 front with lockrite, superior shafts and homemade diff cover
8.25 Rear with lockrite and alloy usa shafts and homemade diff cover
Summit racing rims with 39 bolt weld on beadlocks
on 33x12.5x15 Trxus Mt's with just over 1k miles on them.
freshly painted dark gray metallic this winter but iv already put a few dents/ scrapes in it this spring on the trails..
Im sure im forgetting a few things,
