injectors
SUA SPONTE
Pacific N.W.
I need to replace my injectors but im not looking to spend the 60 plus dollars a piece local. Does anyone know a good place to get a deal? Also should i just get oem replacments or is there "performance" upgrades worth looking into- I am a fuel system newb so i appreciate your patience-
Cheers
RLTW
forgot to mention: 242 renix in a 87 laredo
Weren't you saying that the injectors you just installed were caused more problems than the original ones because they were different from the injectors that come with Renix XJs. Use injectors that are specified for your year XJ. I think 5-0 sells the OEM spec ones too. You aren't running a stroker or any performance mods, they are fine.
