Yukon 1980-1992 Grand Wagoneer ALMOST complete front chromo axles
T to the B
Lenoir City, TN
Kit is only missing ONE stub axle to be a complete kit.....I used it when a broke tie rod that took my current one out.
The complete kit new is like 400+ bucks....i'll sell these for 200...not shipping Both inner axles and one stub, located in Lenoir City, TN
PM or TEXT...text preferred 865-363-6664
30 spline inners with 19 spline outers, brand new never used. The tags say it fits some GM stuff, so check/run the part numbers if you wanna know what else it will fit. I was using a 1985 Grand Wagoneer axle(driver drop).
Also have "a box" of D44 and 8.8 stuff.....50$ for all of it.
Some D44 6 bolt spindles with nuts, spindle bearing kits, upper/lower balljoints, leaf bolts, leaf plates.....1310 and/or 760 u joints galore....8.8 cross pins/bolts....random "white shocks in the 24-25 extended length....other random stuff....warn premium lock out 19 spline lock out....drive slugs....
Basically a buncha stuff I kept just in case catastrophic failure.
