OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
What is this sound?????
I recently (last week) rotated the tires on my '92 XJ. The day after doing so, I began hearing a loud clicking sound while coasting or lightly braking. After a week, it seems to have gotten louder and more frequent. It only happens when I let off the gas, or if I tap the brakes. I had my dad drive it up and down our street and it sounds like it's coming from the middle of the undercarriage. We were thinking possibly U-joints going bad?? Anyone else had this similiar problem? I have to commute on the freeway and don't want some catastrophic failure while going 70mph. Any help is GREATLY appreciated!
1992 Jeep Cherokee Sport, 247,000 miles, AW4, NP231, auto, 3 inches of lift. |
#2
Re: What is this sound?????
Get underneath and check all the U-joints. They make the clicking noise when there's no more grease coating the needle bearings. If they're really bad then the joint will visibly wobble when you apply force to it.
#3
This may be a stupid question, but how would I go about greasing them? Is there a zirc fitting on the stock u-joints?
I got up under there and checked the U-joints for any play, but couldn't get any. They seem to be solid. Last edited by Dvipercop; May 17th, 2006 at 22:05. |
#4
#5
Thanks for link MJ6000. I got under there and greased everything I could, but unfortunately I still get the loud, rapid clicking sound when coasting or lightly braking. Any other suggestions??????
#6
Not to be insultingly obvious, but have you checked the lug nuts? The Jeep alloy wheels do not have steel inserts in them, and it's pretty common for them to loosen even if they were properly torqued the first time.
#7
Rev |
#8
Check your wheel hub assy.
#10
Put it up on jackstands and see if it does it, then *carefully* * VERY carefully* crawl from front to back trying to isolate it...
Thread Tools | |
Display Modes | |
What is a sound bar? | montanaman | OEM Tech Discussion | 17 | March 14th, 2006 21:54 |
Sound.... | uvaldetxj | Jeep Street and Performance | 15 | October 8th, 2005 19:45 |
please help-POP sound | adrnalinlovr | Modified Tech Discussion | 1 | June 28th, 2005 23:32 |
Sound Bar | BobCSmith | OEM Tech Discussion | 14 | December 4th, 2004 09:25 |
