Old August 25th, 2019, 20:03
vimoto vimoto is offline
electric fan is always on!!!!
my xj 2001 fan is always on even on mornings on cold start, temp sensor is new, tjermostat new fan relay new. any ideas? temp gauge is up and down most of the time is down to 0 after 30 or 40 mins of driving
Old August 26th, 2019, 06:31
RCP Phx RCP Phx is offline
Re: electric fan is always on!!!!
Well both the fan and gauge are controlled by the PCM. I would check for good grounding before anything else.
Old August 26th, 2019, 07:43
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Originally Posted by vimoto View Post
. temp gauge is up and down most of the time is down to 0 after 30 or 40 mins of driving
Explain this more completely, the temperature gauge should show about 195*-210 after the engine is warmed up.
Is the Check Engine Light ON ?
Disconnecting the Coolant Temperature Sensor (CTS) makes the PCM turn the e-fan as a fail-safe. I would suspect a faulty CTS, a faulty e-fan relay, or faulty wiring related to the CTS, fan relay, or e-fan.
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old August 26th, 2019, 08:33
Saudade's Avatar
Saudade Saudade is offline
Is this a new to you XJ or did you do some other work on it and then this started?
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old August 26th, 2019, 13:07
alwayzAMC alwayzAMC is offline
also check to make sure you don't have the A/C on, the fan will come on if the AC is on, i don't have a working AC to test if it stays on reguardless of engine temp though. iirc the A/C is on when defrost is selected too in the 00/01
Old August 26th, 2019, 15:11
Tim_MN's Avatar
2000/01 the e-fan only turns ON when required, ( a/c or defrost on or off ). 1997-99 the e-fan cycles on/off when a/c or defrost is on. The e-fan always on strongly suggests a faulty CTS, a faulty e-fan relay, or faulty wiring related to the CTS, fan relay, or e-fan
Electric Fan 96NYXJ OEM Tech Discussion 8 April 8th, 2010 19:35
electric fan? poomero Sierra Chapter 6 March 31st, 2010 22:27
Should I get an electric fan? green_machine Modified Tech Discussion 5 January 20th, 2010 14:34
should I have an electric fan??? GodSpeed OEM Tech Discussion 5 June 6th, 2005 19:09
electric fan sprinkler1228 Modified Tech Discussion 4 August 25th, 2004 13:10
