Anyone running a Hydro Assist on their XJs ?
I was wondering what point you used to mount the other end (not the drag link side)
Any Pics ?
thanks for the help
The draglink runs from the pitman arm (on your steering box) to the passenger side knuckle. The tie-rod ties the two steering arms together, that's usually where one would mount a ram.
WTF is this guy talking about? Do you mean fully hydraulic steering? The subject is hydraulic assist questions........... And it's not 'hydro' as that means water, it's hydra as in hydraulics.
Full hydraulic steering is: orbital valve, pump, filter(s), cooler, cylinder (usually double ended self-centering).
My ram is mounted at the tube joint where the long side meets the center section. I used a 1.5 dia x 8" stroke x 1.125 shaft ram from www.surpluscenter.com, it's made by Chief.
was just a little too simplified to not poke fun at.
I know what and where a drag link is, and what and where a tie rod is. cmon
And my Drag doesnt run to the knuckle, it runs to the tierod. But my question was, where are they bieng mounted
I guess I should have worded it a little different.
