Old March 7th, 2009, 17:53
RichP's Avatar
RichP RichP is offline
Ebay headers
Looking at the headers on ebay, prefer the ones with the flex in the tubes. Who has had the best luck with fit and which buyer.
I looked at these two, they seem the same.
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
Old March 7th, 2009, 19:37
winterbeater's Avatar
winterbeater winterbeater is offline
Re: Ebay headers
The Chinese price is great, but to me, the bellows make no sense. I don't see how they would change the common cracking issue which has been attributed to worn out engine mounts.
Old March 7th, 2009, 21:00
wolfpackjeeper's Avatar
wolfpackjeeper wolfpackjeeper is offline
Re: Ebay headers
rich, just get the APN, you know you want it anyway
Old March 7th, 2009, 21:04
tomhil tomhil is offline
Re: Ebay headers
Those look like a standard replacment manifold? As said the cracking issue still looks apparant there. Power also wont change with these. I dont know what to say... those both dont look any good.
I would keep searching. Good luck
Old March 8th, 2009, 04:37
RichP's Avatar
Re: Ebay headers
I"m looking for the flex tube type they put on the newer 4.0 TJ's, mines been welded about 5 times now but the next crack that is just starting is out of reach of the welder so I figure if it has to come off I might as well replace it so if it does crack again I can start with a clean sheet of paper so to say
Old March 8th, 2009, 05:46
98 jeepjeep's Avatar
98 jeepjeep 98 jeepjeep is offline
Re: Ebay headers
Rich i have this header.....I bought it from a company called best automotive on Ebay...The header has a Liftime on it. This Header is Huge way bigger than a stock header. Its built like a tank fits like a glove....APN has a reputation of cracking but they have probally fixed that by now. I wouldnt spent any more $$ on a header than this one... you wont gain anything for the extra $. I have 10K on mine now with 0 issue's.
Old March 8th, 2009, 06:30
RichP's Avatar
Re: Ebay headers
Which header !?!?!?!
and what is APN ?
Old March 8th, 2009, 06:34
Re: Ebay headers
APN is a brand of header sold for the 4.0. I have the same one from ebay your looking at but i bought mine from best automotive...go back on ebay and look for the comapny that uses the girl to model off the header.
Old March 8th, 2009, 08:29
Re: Ebay headers
http://cgi.ebay.com/ebaymotors/91-99...Q5fAccessories
Old March 8th, 2009, 08:37
RichP's Avatar
Re: Ebay headers
I'll probably go with this one, I like the flex pipes, might help it not to flex/crack again.
http://www.jeepsareus.com/Merchant2/..._Code=CHEROKEE
I'll keep them all in mind though.
Old March 8th, 2009, 09:10
1991XJCherokee's Avatar
1991XJCherokee 1991XJCherokee is offline
Re: Ebay headers
HOly 200 Dollars
Old March 8th, 2009, 09:34
Re: Ebay headers
Why do you think that one is any better than the one on ebay for $89 from Breast Automotive? They look the same. What about the turbulence that those bellows would create in the outer two pipes? Sure doesn't seem like those reduce the stress where they crack at the last collector.
Old March 8th, 2009, 10:43
RichP's Avatar
Re: Ebay headers
Mostly from what one of my customers and friend says, he does quite a few jeeps, his main comment was that once jeep started using the flex coupled headers from the factory he noticed that he never got one in for repair of the exhaust manifold except for loose or missing fasteners. One of the neat things you can do with the shop key software is searches, 'exhaust manifold weld', all the jeeps that came up with that repair were 2000 on back, TJ's, XJ's and ZJ's plus a few WJ's too as well as a bunch of Neons and other cars which I thought was interesting. I'm still looking around, I may hit a pick and pull and yank a used on off, we'll see, I'm not in a hurry as mine is just a pinhole right now that I can live with.
Old March 8th, 2009, 10:47
DeftwillP's Avatar
DeftwillP DeftwillP is offline
Re: Ebay headers
I haven't heard of apn's cracking. I put one on mine a few months back and have had no problems since.
Old March 8th, 2009, 11:05
RichP's Avatar
Re: Ebay headers
I had no problem with my 98 for almost 7 years and 200K miles, once I started doing a lot of local driving, close by service calls, a 15 minute run up to the raceway where it barely got warmed up vs a 70 mi one way commute thats when trouble started showing up. Now that I have a solid 25mi/30 minute commute I figure that should even out.
headers? lacherokee96 Modified Tech Discussion 5 May 28th, 2007 13:43
ebay exhaust headers?? play_in_the_mud Modified Tech Discussion 3 June 29th, 2006 23:22
exhuast headers on ebay theschwarz1 OEM Tech Discussion 3 August 2nd, 2005 20:42
After market headers & stock headers 2wdxj Modified Tech Discussion 1 June 27th, 2004 08:47
XJ Items on EBAY & cars on Ebay juicexj24 For Sale: Private Party Only. XJ ITEMS ONLY 1 September 8th, 2003 13:48
