Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter > SEC For Sale / Wanted Forum
SEC For Sale / Wanted Forum This forum is for SE Chapter members to buy and sell XJ parts.
Old November 19th, 2007, 16:50
JLane99XJ's Avatar
JLane99XJ JLane99XJ is offline
$$parting built 99 xj$$
see thread
http://www.caos4x4.com/cmbs/index.php?topic=11809.0
if you'd like a faster reply just call 256 441 4817
Old November 22nd, 2007, 19:20
strong arm strong arm is offline
Re: $$parting built 99 xj$$
what parts do u have for sale
Old November 22nd, 2007, 22:20
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Dude!
Read this link thingy kabob...
Ta da!!!!!!! ...
99 cherokee classic 101k miles $3500 gets the whole enchillada!! including spare parts
w/ Clear AL Title
Call 256 441 4817 Lane
Located Near Gadsden
4.0L aw4 auto w np231j w/sye $make offer on whole drive train will Not sperate
all power windows work $make offer
ac blows cold $make offer
am-fm-cassete & cd!! works good $100 Jensen (i think)
cb-radio works great $50 with cable and k-40 antenna
last few years various components have been replaced with new parts
such as the alternator, starter, power-steering pump, water-pump and radiator
all mechanicalls working
interior good,
body fair/rough
front axle d30
spicer replcaement shafts and 297 joints
dana carrier and all new bearings/seals
4.88 gears professionally installed
Lock-right locker
rear axle D44
stock 30 spline spicer shafts new bearings/seals
upgraded to ZJ disc-brakes
detroit Tru-trac Locker
$1800 FOR THE PAIR/ will not seperate
both axles as mentioned were professionally built by Jimmy Hathaway at A&G Auto in GLencoe, AL
axles aprox have 20k miles on the new gears and bearings, no gear whine or leaking seals..
Tires, 4 BFG Mud-terrains TAs (older/non KM design) aprox 40% tread left all worn evenly, one has a small plug in thread area(nail) 35x12.5xr15
Wheels, 4 Cragar Soft 8s, 8"x15" Black steel, some rock rash on each, one bead had small dent, still holds air/seal fine
$400 wheels and tires together will not seperate
Spare- ~33" lt285,75r15 Gateway-Buckshot mudder on an AR 767 blk steelie 8" $40
bumpers are custom,
front. simple bolt on any xj
rear bolts into rear Uni~frame rails, not simple bolt-on
incorporates spare tire carrier and rear leaf spring/shackles
rocker/guards/sliders custom
2x2 tubing bolt on to any xj w/ some drilling
suspension ~aprox 6" lift *Custom*
front
Rusty's ^6" hydro shocks
4.5" rusty's coils
1.75" poly coil spacers
3" Poly Extended bumpstops
2" LCA drop brackets
custom/modified toyota/DOM LCAs
Rusty's Adj UCAs
Rubicon Express HD trac-bar and frame bracket (modified for OTK steering)
Frankie's Offroad OTK Steering 1.75"dom w/ 3/4"x5/8" Heims and Mis-allignment bushings
rear
MJ Commanche Truck Leaves (longer=flex better)
w/ Rusty's FSJ 3" Long AAL
custom 1" 4-degree tapper lift block/ 6" long (aides in preventing axle wrap/hop)
mj truck shackles+rusty's extended HD xj Shackles
(currently configured together to form a ~revolver-type shackle)
Rancho Rs 5000
( rear shocks mounts on axle raised above the tubes and upper mounts relocated forward on inner frame rails. for better clearence and to aide against axle wrap/hop. )
**This suspension is balanced and works well how it is set-up.
Due to Custom Nature of this Suspension i'm unwiling to part it out Until the Majority of the other parts are Gone! such as axles and drive-train
plenty of other goodies on this jeep
as mentioned this is a feeler to see if parting this out could help me out financially..
as i've said before nothing is wrong with the jeep, and i really hate to sell it considering all the time and money i've put into it, but my circumstance at this point dictate i Must sell it!
$3500 for the whole rig all spare parts included
or make offers on the parts and we'll see how that goes..
C: 256- 441- 4817
Lane
Old November 22nd, 2007, 23:14
Jimbo_1321's Avatar
Jimbo_1321 Jimbo_1321 is offline
wrong side of the state...
Old November 25th, 2007, 13:08
JLane99XJ's Avatar
sold
SOLD
Old November 25th, 2007, 18:42
MELKORsXJ's Avatar
MELKORsXJ MELKORsXJ is offline
congratulations... i know this XJ has been up for sale for some time...
Rate This Thread:
Parting out Semi Built XJ in VA atreyuBLUEXJ For Sale: Private Party Only. XJ ITEMS ONLY 17 August 5th, 2007 21:09
Parting out built 1992 XJ korda SoCal For Sale 99 May 3rd, 2007 09:27
F/S Parting out built HP30 prm99v6 For Sale: Private Party Only. XJ ITEMS ONLY 12 March 9th, 2007 18:11
parting out built xj wvredxj For Sale: Private Party Only. XJ ITEMS ONLY 6 March 7th, 2007 17:35
Parting out Built XJ (PICS) KarmirXJ For Sale: Private Party Only. XJ ITEMS ONLY 16 January 17th, 2004 19:18
