Roxtar
- NW Indiana-Chicago area
Yea, it's the one
One son in college and one in law school creates new priorities.
’99 XJ Classic 4.0 Auto
77,000 miles
Interior:
Cabo Eng 8 pt cage tied to frame rails
Corbeau Forza Racing seats
4 pt harnesses
Art Carr Racing shifter
Herculined using HyTech ceramic insulating beads in the Herc.
Exterior:
Cabo Eng F&R bumpers, rails, and fender protection; all tied into frame rails.
Cabo Eng roof rack
Rear lower quarters removed and welded
Cabo Eng bulletproof X-member, TC skid, & gas tank skid
Front Axle:
HP44 shortened to Waggy width.
Retubed using 3” x 2” 4140 alloy.
Trussed using 3” x 2” x .250 wall rect tubing
HD coil buckets & CA/TB mounts.
Dutchman inner/Warn outer alloy shafts.
Jantz Superjoints
Warn Premium hubs
5.13 gears
ARB locker w/ HD line kit & pneumatic switch (eliminates ARB solenoid)
Ridiculously overbuilt diff cover.
Rear Axle:
8.8 w/ disc brakes
Tubes welded and 3” x 3” x .250 wall sq tube truss.
Moser alloy shafts with both 5x5.5 and 5x4.5 bolt patterns
Lincoln locked.
Cabo Eng diff guard
Front Suspension:
URF 3 link w/ RE Superflex joints.
2” x 1.5” control arms w/ 1” grade 8 threaded rod (RH & LH threads)
6.5” RockKrawler coils
Bilstein 5150s
Rear Suspension:
4 link w/ RE Superflex joints.
Fox 2.5” x 16” travel AirShox.
Cabo Eng Anti-Roc sway bar.
Steering & Chassis:
Cabo Eng high steer system.
1.25” x .250 wall tie rod & drag link
Aurora heims
1.25” solid 1050 steel track bar w/ Aurora heim/RE Superflex ends.
Frame rails sleeved w .250 wall
Wheels/Tires:
(5) 35-12.5X15 Maxxis Creepy Crawlers on TrailReady alum beadlocks.
Misc:
Warn 8274 winch w/ Amsteel 3/8” line.
Dual Optima batteries (Redtop for main, Yellowtop for aux) w/ Painless style switching.
165 AMP alternator.
OBA system w/ 1HP electric compressor.
(6) Hella 500s in front (2) Hella floods in rear.
All hardware is GR 8 or above.
Pics will be coming.
Extremely low use on build, tires less than 10% wear.
Rust free but plenty of "character"
Many on the boards here can attest to the quality of this build.
Looking in the $10K neighborhood
My cost over twice that.
To have built would be well over 3X
77,000 miles
Interior:
4 pt harnesses
Exterior:
Cabo Eng roof rack
Front Axle:
Jantz Superjoints
Warn Premium hubs
5.13 gears
Rear Axle:
8.8 w/ disc brakes
Lincoln locked.
Cabo Eng diff guard
Front Suspension:
Bilstein 5150s
Rear Suspension:
Steering & Chassis:
Aurora heims
Wheels/Tires:
Misc:
165 AMP alternator.
