NOS/86
- chattanooga, tn
this is a very random problem that i've been trying to track down for a couple of months . and it only does it when wheelin . ?????
1st off , you can just be ridin down a trail and it'll start running rough . starts popping thur the exhuast . and wont hardly idle . (smells like it's running rich ) you can put it in netrual rev it up and clear it out . then it's fine . or sometimes you can cut it off and it want start . (acts like it's flooded out ) just a touch of starting fluild and it'll start right up / or let it sit for awhile and it'll start fine .
heres whats new ..... cat (nov 05 ) , 02 senser (nov 05) , plugs , wires, cap , (jan 06 ) thought fuel pump was bad . (jan 06) was bad filter , check fuel pressure . was ok .
any ideas ? i'm about to check the map senser , clean the k&n filter and try some insulation on the fuel lines .
btw its a 1990 xj ,4.0 auto,242t-case .
