ARB Air Lockers at Just Differentials - New Price Reductions
Just Differentials
Differentials and Axles!
Washington State
The same great ARB Air Lockers that have been trusted for years are now more affordable. Across the board ARB Air Lockers have come down in price, you can see the new prices on our website. Check out all the different locker models and see their new lower prices here: ARB Air Lockers
With our improved two piece design available right across the range, along with the addition of forged gears and an industry leading five year warranty, ARB Air Lockers are now better built and better backed than ever before.
Created to provide 100% traction on demand, without sacrificing any of your vehicle's highway driving performance, ARB Air Lockers employ a 12 volt ARB Air Compressor designed to activate (and deactivate) a solid and durable locking mechanism inside the differential. This gives you the traction you need, when you need it, all at the flip of a switch and all within the comfort of the driver's seat.
The advantage of the ARB Air Locker lies in the pneumatically operated locking system inside the differential. When activated, the Air Locker prevents the differential gears from rotating and therefore prevents the axle shafts from turning independently of each other. With both wheels tied directly to the rotation of the ring gear, the vehicle maintains maximum possible traction at all times. When unlocked, it operates just like a conventional 'open' differential.
In addition to providing outright improvements to a 4x4's off road capabilities, the Air Locker offers significant environmental benefits. An Air Locker equipped vehicle can be driven in a slower, safer and more controlled manner, greatly reducing the likelihood of vehicle damage and environmental impact.
Required Parts:
  • ARBCKSA12 air compressor (extremely compact, operates up to 2 air lockers, not intended for oversized tire inflation) or
  • ARBCKMA12 air compressor (compact, operates up to 2 air lockers and will inflate tires when paired with a 171302) or
  • CKMTA12 air compressor (still compact, operates up to 2 air lockers when pairedARB with 171503, will inflate tires AND run air tools when paired with a 171302 and will run even faster when paired with a171501 air tank
Optional Parts:
  • ARBALSB3 - bracket for mounting three (3) rocker switches. Manufactured from steel and powder-coated black. (Suitable for mounting both a front and rear air locker and a compressor switch.)
Bumping this back up! You can buy an Air Locker Package (complete with a replacement differential, activation switch, solenoid valve, air line and bulkhead fittings) or just the ARB Air Locker. We also sell all the ARB accessories, including air compressors, air up kits, and everything else you will need. Give us a call at 866 349 6801 or email us at [email protected]!
The ARB Airline Accessory Pack is now available!
This kit includes all the pieces you need to connect your ARB Air Locker equipped axle to your air source, including the required switch in one convenient kit. It is ideal if you are installing a used axle assembly into your rig and did not get the solenoid, fittings and other parts from the previous owner. This kit also makes for a perfect ARB trail spare kit for your ARB Air Locker equipped 4x4.
Follow this link for more info, or to purchase:
We are huge fans of the ARB compressors and stock them in both our warehouses along with ARB Air lockers. This video gives a nice overview of the portable compressor kits and performance levels with the different units.
ARB Air Compressor Video
You can check out all the options and pricing on ARB compressors here:
ARB Air Compressors at JustDifferentials.com
