Old November 6th, 2017, 17:26
Jeep Driver Jeep Driver is offline
Re: Wack's D44 Build 1996 xj
https://scontent-ort2-2.xx.fbcdn.net...1b&oe=5A5D1E16
What steering damper is used here?
Old November 6th, 2017, 21:59
RCP Phx RCP Phx is offline
That's not a steering damper.
Old April 2nd, 2018, 05:40
zaroot zaroot is offline
Made some good progress. Still have to ream out pitman arm, make drag link, do brake lines front and rear, and vent tubes.
Old April 2nd, 2018, 05:44
Old April 2nd, 2018, 05:57
Was also able to build a new front bumper, do some patching in the cargo space, install brown dog engine mounts, and swap in a 4:1 241 rocktrac case.
Old April 10th, 2018, 04:48
Old April 17th, 2018, 05:54
Got front axle squared away and centered. Rear brake lines fabricated and new Bilstein shocks installed. Waiting on a reamer for pitman arm and then itís pretty much complete and ready for trial
Run.
Old April 22nd, 2018, 13:17
Old May 7th, 2018, 08:02
Old May 14th, 2018, 09:21
Old May 14th, 2018, 12:23
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
Sittn purty
Old May 14th, 2018, 13:18
srb531 srb531 is offline
just saw you at the the big dogs event, btw where did you find the 241 tc ?
Old May 15th, 2018, 03:56
The last time I was at BD was early December, was cold AF. I sourced the case off eBay, found a "for parts" unit that had the fill plug boss snapped off. Bought it for cheap, and welded in a replacement aluminum bung w/ stainless plug for about $10. Got really lucky, as I have seen these go used for over $1500.
1996 Cherokee Country DD/WW build (infancy) YoungAndJeepin Modified Tech Discussion 58 August 13th, 2014 23:38
1996 Jeep xj (Pegasus) Build megamanmojo North Atlantic Chapter 25 March 30th, 2014 17:58
track bar bracket=out of wack steering wheel 4xfishfinder Modified Tech Discussion 9 February 25th, 2013 09:28
Rear 1/4 panel wack Fenris Modified Tech Discussion 6 June 21st, 2003 18:05
