Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old May 17th, 2019, 19:19
bradleyheathhays bradleyheathhays is offline
How to disable my airbag *gasp*
So my Mom drives a 2002 Ford Taurus that I believe has one of the Takata airbags that have been killing people. So far her car hasn't been recalled for the airbag, but I know this recall is being done piece meal as they can't do them all at once, and since the recall applies to the year right close to hers I suspect hers eventually will be recalled as well. Either way I don't want to take the chance, and here's why...
The explanation for why these things are going off is there's some defect in the manufacturing that when the air bag is exposed to humid conditions and lots of temp fluctuations, something in them weakens and there they go. Mom's Taurus has a windshield leak so, even though it's never smelled, there's always been a virtual puddle of water in driver's side floor board. So the inside of the car has always been humid, just like in the airbag explosion scenarios.
So, for the time being, until she gets into another car, I'd like to disconnect her airbag to be on the safe side. She is an amazingly vigilant driver, never even a speeding ticket, and the risk of her rear ending someone is virtually non-existent.
How would I go about disabling an airbag on a 2002 Ford Taurus?
Or, alternatively, how do I open the steering wheel column, or front of the steering wheel, which might be part of the disabling process itself, and identify if Mom's airbag is indeed one of the defective types?
Old May 17th, 2019, 21:00
devildog0's Avatar
devildog0 devildog0 is offline
This should be a covered recall item. Call or take the car to Ford and see what they say you can look up the info via the VIN.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old May 17th, 2019, 21:01
devildog0's Avatar
https://owner.ford.com/service/frequ...bag% 20recall
Rate This Thread:
Disable ABS in '00 spinaldex OEM Tech Discussion 6 May 29th, 2014 17:43
Disable ABS AL BUNDY OEM Tech Discussion 6 December 1st, 2011 07:46
Dropping an aw4 into a *gasp* TJ, what flexplate? 4ward Modified Tech Discussion 30 August 1st, 2007 13:46
Disable ABS? The Buck OEM Tech Discussion 0 May 9th, 2004 13:18
disable airbag on a '98 John D OEM Tech Discussion 15 May 2nd, 2004 20:58
