Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
Old July 12th, 2019, 15:28
jcnoble's Avatar
jcnoble jcnoble is offline
Got a M2500 scanner , now what
I got my Snap On MT2500 Renix Scanner in the mail today, it is a little beat up and greasy but works just fine. I am able to read all the streaming data but does anyone know what "normal" numbers should be. Timing and MFI pressure and parameters like that would be helpful to know to "tweak" the system for optimal performance or emissions. Plus the mixture parameter keeps switching between lean and rich. I found all the parameters in a snap on manual but it only lists the range of each parameter which is of no use to me. I really could use a normal parameter printout or something.
88 XJ Renix Patina Color
4:56 Gears
35" Tires
Long Arm y-Link
Old August 4th, 2019, 22:52
uglyrenixxj uglyrenixxj is offline
Re: Got a M2500 scanner , now what
Nickintime on youtube has a video on the 2500 and renix. Its not al9t of data, but he explains most of it, and has the REM deallydoo. Hes done alot of work for the renix crew
Old August 4th, 2019, 23:02
https://youtu.be/qPV5pEGUHWw
Old August 5th, 2019, 06:51
old_man's Avatar
old_man old_man is offline
The switching between lean and rich is the one lambda sensing method the ECU uses, and is normal. As far as tweaking...how do yo plan to do that. About all I have been able to do is spoof the MAP sensor and the ACS sensor to dial in my Renix stroker. Without a Air Fuel Ratio gauge you are shooting in the dark.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Rate This Thread:
ODB II scanner in OC djblade311 SoCal Chapter 7 July 11th, 2010 20:30
Lap top Scanner Khary23 OEM Tech Discussion 41 March 12th, 2010 15:43
Anyone in MD with a DRB scanner that can help me fix my XJ? getblown5.9 North Atlantic Chapter 5 September 11th, 2009 07:25
Scanner jeepboy_90 Sierra Chapter 1 April 14th, 2006 17:16
scanner trailrunner For Sale: Private Party Only. XJ ITEMS ONLY 1 January 22nd, 2005 15:00
