Parts from build
dave92cherokee
Lynchburg, TN
In the process of building the cheromanche and have some parts to get rid of. All prices are OBO so make offers to get this stuff out of the way. And if you recycle scrap metal and want the chassis after it's stripped down let me know as they're available as well.
1988 MJ front end from windshield forward bare chassis
1993 XJ back end from C pillar to D pillar
D30 vac disconnect from MJ 3.07 gears complete with roller wheels $50
Front driveshaft from MJ 4.0/MT (BA-10) $20
C8.25 open from XJ 3.55 gears complete from drum to drum with e-brake $50
XJ rear hatch with tinted window (cheap home job) $20
XJ rear hatch window $10
XJ rear side windows $15 for the pair $10 each
XJ rear carpet tan color (fair condition) $20
XJ 97+ rear seat grey color (good condition) $30
XJ rear bumper stock FREE
XJ gas tank with pump (dented but no leaks) $20
MJ 4.0 block with heads and valve cover (good block for stroker build) $50
MJ 231 T/C for BA10 tranny $25
Renix wiring harness 2 sets could be combined to make one entire set Make Offer
MJ steering column with key non-tilt $10
XJ bastard pack leaf springs 4.5" lift still stiff $25
Few other odds and ends will be posted as the build progresses and I will update this thread accordingly. If interested reply to the thread or PM me and I will get back to you. I'm going to be gone for a couple of weeks and plan to return on the 30th so depending on item of interest it may have to wait till then to pick it up.
Ok I'm back home and will hopefully be here for a while so I'm throwing this back up here to see if I can get some of this stuff cleaned out to make some room and make some money to buy parts.
It's the renix engine I pulled out of the manche.
Bringing this back up to the top. Gonna get some ink done today but can help pull parts this weekend. Sounds like thechief could use the 4.5" lift that I've got. Mark's gonna pick the welder back up today so I'm going to take a break on the cheromanche and work on getting the left overs stripped down to get them out of the way. Also to add to the list is tan carpet from front to rear.
dave, i'm coming to your house with mark, so i might try to talk you out of the lift while i'm there. i really just need coils and shocks, but i'm interested in whatever you have!
it's been a couple of months and I'm finally back home now hopefully for a while. Bringing this back up to see if i can get some of this stuff cleared out of my way. i've got the axles pulled, the rear of the xj gutted, and the front of the mj gutted as well. Let me know what you're interested in and make an offer so I can get some of this stuff out of my way.
Yes it's renix and not sure on the weight but I've heard that the HO block weighs around 400lbs if I'm not mistaken.
Bringing this back up and adding in the 97+ front seats and rear bench. Also have a 97+ charcoal center console would like to trade for tan 97+ console to match the new leather seats going in the jeep.
Update on what's left:
XJ 97+ front buckets grey color (good condition) $50
XJ gas tank with sending unit minus pump (dented but no leaks) $20
MJ 4.0 renix intake with injectors, throttle body, air intake tube $20
MJ steering gear box $20
97+ grey center console would like to trade for same in tan color
Listening to all offers and possible trades
Looking for:
xj 96- 2 door glass both sides
97+ front clip
97+ front doors (full power)
Looking for:
97+ front clip
Everything is still available and I'm desperate to get it out of my way to clear up some space. Make me some offers on it and come get it out of the way, some of it I'd even be willing to give away just to get rid of it.
renix wiring harness?
is that the truck chasis wiring or the engine harness wiring.
I have 2 sets that are the engine bay and the dash harness.
XJ rear side windows pair
XJ gas tank (dented but no leaks)
***Ok after having this stuff laying around in the limited amount of garage space I have and the back patio area I need it gone. There's been 580 views of this thread and only a couple of parts have been sold in the several months I've had it. So in the spirit of Xmas and the coming new year here's the new deal.
I NEED this stuff gone so I can have room to work and get things done, so from now until sunday evening everything is FREE for local pickup only. Plenty of good items to use or have as spares or for building up before swapping in. If interested just PM me and I will get back with my address asap.
