Old October 5th, 2019, 07:00
RCP Phx RCP Phx is offline
A little Pep in my Strokers step.....
I finished installing my 1.7 rocker arms to replace my 1.6's. It runs quieter than ever but no "big" change in performance, I haven't had a chance to put the scanner on it yet. I have a feeling that might need to re-install my 27# injectors. My cam is the Comp 68-232-4 so the new lift is .491" Int/ .508" Exh.
Old October 9th, 2019, 21:27
Re: A little Pep in my Strokers step.....
It's running so good! I don't want to spend the coin down at the dyno shop again but I am thinking about the "Run what you brung" Friday night drags. What would be a good time for a "flying brick"?
Old October 10th, 2019, 06:48
Cummins90 Cummins90 is offline
https://youtu.be/gd6K3a89cSE
This is the time to beat.
Old October 10th, 2019, 08:10
That's cool but sure not realistic! Now add 5.5" lift, 33's and some winch bumpers and rock rails.................
In 60yrs I've only been maybe 3 times to the drags so I don't know what a realistic time would be.
Old October 10th, 2019, 09:54
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
What rockers did you go with and can they run with an unmodified stock valve cover?
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 10th, 2019, 12:12
I'm trying the Scorpion rockers and I had to remove my baffles for the HS's.
https://naxja.org/forum/showthread.php?t=1155822
Old October 11th, 2019, 07:08
cherokeecrawler's Avatar
cherokeecrawler cherokeecrawler is offline
I've seen turbo 4.0s on 15psi run 14 flat, so I'd say running 15 in the 1/4 would be pretty decent imo. Let us know how it goes, I'd definitely like to be able to base mine on something.
Old October 11th, 2019, 19:38
Those sound like some good numbers to shoot for, the next R-W-B is on the 8th so hopefully I can get my JK coil conversion done by then.
step by step gearing writeup or link? outlander Modified Tech Discussion 10 June 3rd, 2010 22:41
Step by step write up strokers Robahr24 Jeep Street and Performance 5 December 11th, 2008 10:48
Motor Mount Replacement - Step by Step kd5dwy OEM Tech Discussion 15 February 9th, 2007 09:22
Budget Long Arm step by step build COMING SOON! barillms Modified Tech Discussion 12 January 31st, 2007 20:08
QUICK STEP BY STEP ON FUEL PUMP REPLACEMENT afjeep2082 OEM Tech Discussion 8 July 10th, 2006 15:43
