Transfer case skid for Clayton long arms
WaXJ_Skier
Bellevue, Wa
Anbody know of a transfer case skid or full bell pan that will work with Clayton long arms?
I made a skid for my t-case out of an old Ford Ranger skid I had laying around. If you have basic fab skills, it's not too tough to do. I don't know specifically of one made for the Clayton's x-member, but it's a nice thick piece of steel with a flat bottom, a reinforced flat plate can be located to it with several self-tapping bolts. That's essentially what I did.
You don't even have Clayton's longarms you liar :pirate1:
hahaha
Serious note, I don't know of anyone that makes a compatible one with that style of crossmember. Probably gonna need a custom one off. You could probably make a factory t-case skid work after modification.
I'd give Clayton a call, he does one that fits if you have rear coild conversion as well. He's been pretty helpful whenever I've called about RHD parts.
Um, yes he does.
I've reused the stock skid plates on most of the rigs we've done the Clayton's stuff on. Either drill/tap two holes in the crossmember or just a couple of litle stitch welds.
Nick (outlawjeeper) has a Warn t-case skid on his rig /w the Clayton's setup that fit REALLY nicely. I'll try and get a pic of it up.
J
Avanteone said:
Um, yes he does.
J
Eli was going to put my stock one back on... but mine Xmember is an inch lower because of the of the manual tranny
