Those Familiar with Jantz/Yukon U joints...
LouisianaZJ
NAXJA Member #1362
Louisiana
i have been running some jantz/yukon super joints for about a yr. maybe 6 wheelin trips on them.
i was going on a trip tommorow and i saw one of the joints had the copper grease around the joint. i clened it off and regreased (no noticable leakage while greasing). took for a test drive and i could see where some had oozed out....
looks like one of the orings between the cap and cross has gone bad. can i wheel on this tommorow or should i swap in a spare shaft?
also is it possible to rebuild/dissasemble the joint without messing it up? it was a PITA putting it together due to the huge cross and the alloys... anyone taken one apart before off a ujoint? tips....
also on the opposite side i think i saw a small fatigue crack on a superior alloy ear....
:gonnablow
They aren't really that difficult to take apart.
As long as you put it together with the recess in the right spot, you'll be okay.
I think it'll be fine for a trip.
The anti seize in it will keep out the elements.
leak
warn shaft.. crack or machining defect?
superior SMALL fatigue crack? i removed the paint..still cant really see it in pictures...
http://img228.imageshack.us/img228/2038/yukon0080wi.jpg
about taking them apart. i remember i had forgotten a spring or oring when i first put them together and had a hard time getting the cups pushed out far enough to grab onto it and pull it all the way out or something like that. if i take it apart i am replacing all the orings for sure
LouisianaZJ said:
leak
That "fatigue crack" just looks like a casting mark to me.
Hard to get a good look at it though with the fuzzy pictures.
I concur
