Need UCA bolts...
BruceB83
Dacula, Georgia
I want to have a spare set of UCA bolts on hand next weekend for when I pull my front axle out for the rebuild/regear just in case they freeze up in the sleeves like my LCA bolts did. I had to cut three of them out when I put my new LCAs in and luckily I had enough spares. I think the UCA bolts are the same as the LCA bolts.
Anybody have some?
I got my spare bolts from team cherokee none of the parts stores or hardware
UCA bolts are smaller than the LCA bolts, I picked up some bolts from the hardware for the axle end. I can't remember the size but they were grade 8 or metric equivalent.
UCA are smaller. ANd the frame side are different then the axle side. Sort of. I have a set of frame side ones in the red jeep out back.
Son of a .....
Well, I don't think I need them now anyways. I think the D30 rebuild will be occurring with it IN the vehicle now as opposed to on the bench. I'll be able to get it about 3 feet off the ground so shouldn't be too bad.
