razrwild
- paulsboro, nj
1987 jeep comanche
5spd manual
4.0 liter
221k miles
4x4
on 31's with AR rims
2" RE lift installed
the good
has a set of payload toolboxes on the sides (over the side rail toolboxes)
new wheel cylinders and back brakes
new back brake lines
strong functional front brushguard with 2 9,000 cp sealed utility lights
replaced the radiator, upper radiator hose, thermostat, thermostat housing, water pump, water pump gaket, 2nd set of tires with it with about 5k left on em
bucket seats
electric fan is set on an on/off switch
bypassed rear height/load sensing valve
engine sounds strong
no noises of out trans
4wd does engage and disengage fine without noises while running
new serpentine belt
the bad
hole in drivers side floor of decent size
needs front calipers (bleeder screws frozen inside)
emergency brake not hooked up
door striker on drivers side door is a bolt (have a replacement striker but didn't install)
has rust on the undercarriage but doesn't look too bad, just surface
swaybar disconnects were rusted up pretty good so Its hobbled together to work (haven't driven on it so don't know)
just needs minor putting back together work done
windshield cracked
bottom seal of power steering box has a drip
I'm including with it a spare renix injection setup that worked when pulled and a set of front pads i was going to put on but ran out of time on
I'm not going to be able to take any pictures other than the ones that
are here since I'm moving back to NJ and can't take the truck with me. The truck is at my mom house in New Port Richey, FL. If you'd like to see it just give me a call and we can set that up. I'm looking for $700 obo since this truck will run and drive as is but needs tweaks here and there to make it right. If you have any questions call me at 856-889-5561
5spd manual
4.0 liter
221k miles
4x4
the good
bucket seats
new serpentine belt
the bad
windshield cracked
