Old July 10th, 2019, 11:07
chickenbot chickenbot is offline
Re: Tera 2 Low kit with a wide chain
That parts list should be a sticky lol
Old July 10th, 2019, 11:08
And thank you too
Old July 15th, 2019, 15:36
Groot99 Groot99 is offline
I was literally ready to pm you for this info lol. Thanks!!
Here is what I came up with......
Rocker arm studs ARP 200-2403 nuts for use with HS roller rockers ARP 300 - 8331
Valve cover studs ARP 200-7603
Head bolts ARP 146-3601 studs are ARP 146-4201
Crankshaft main studs ARP 146-5401 bolts are ARP 146-5001
Oil pan studs (1/4") ARP 200-7601 (5/16") ARP
Flex plate bolts ARP 146-2901 Flywheel bolts ARP 146-2801
Some misc studs had to be extended for auxillary items to be mounted.
All exterior/gasketed nuts were SS serated flange nuts.
All the misc hardware I got from McMaster: Transmission studs - SS 6mm x 1.0mm x 25mm
Transfer case - SS 10mm x 1.5mm x 50mm
TC tail cone - 8mm x 1.25mm x 35mm
Rebuilt NP231 HD, 6 pinion, wide chain, Tera 2Low, JB SYE hot_rod_hooligans MWC For Sale/Wanted Forum 8 April 26th, 2013 10:16
WTB: NP231 Wide Chain Kit djblade311 SoCal For Sale 3 October 7th, 2011 10:23
Wide chain kit... just curious. Mr. mud Modified Tech Discussion 7 April 8th, 2010 01:32
NP231 wide chain kit NIB! BillR For Sale: Private Party Only. XJ ITEMS ONLY 4 May 27th, 2006 18:52
231 Wide drive chain Boatwrench OEM Tech Discussion 2 March 15th, 2006 20:02
