Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > NAXJA Vendors Info and Feedback Forum
Closed Thread
Old May 5th, 2006, 09:47
TrailHunter's Avatar
TrailHunter TrailHunter is offline
NAXJA Member #1309
XJ Sliders Discounts for Naxja Users
For the month of May I'm offering Naxja users (yes both members and freeloaders ) a 30 dollar discount on our sliders. You can use it towards both the .120 or .188 wall versions. Enter the code "naxja" during checkout to cash in this oportunity. You can read more about the sliders here, https://4x4trailhunterscom.secure.po...roduct_id=1564
  #2
Old May 5th, 2006, 16:11
jeepboy_90's Avatar
jeepboy_90 jeepboy_90 is offline
Re: XJ Sliders Discounts for Naxja Users
Will they work with TNT LA?
  #3
Old May 6th, 2006, 09:49
NAXJA Member #1309
I don't have access to a set where I can tell you with absolute certinty. However, looking at their pics, the sliders probably will not fit. I also looked at their sliders and the center leg is not centered, which is probably to clear the pan.
It would be very easy to build a set for you with the center leg moved back.
  #4
Old May 6th, 2006, 10:09
Starscream's Avatar
Starscream Starscream is offline
Those look really nice. Do you have some better pics of the pinch seam mount?
  #5
Old May 6th, 2006, 22:33
NAXJA Member #1309
I don't have any better pics because there isn't really a pinch seam mount like what's found on most other sliders. The square body sits flush againts the rocker panel and pinch seam and you use self drilling screws through the seam into the square body. You only loose about 1.25" of ground clearance mounting them this way and the force of an impact gets spread accross the whole rocker panel rather than 2 or three pinch seam mounts.
  #6
Old May 12th, 2006, 10:40
lost1's Avatar
lost1 lost1 is offline
do you normally run a discount on the rest fo your gear or is this more a one-time type thing?
I'm planning on getting your front and rear hooks set pretty soon.
  #7
Old May 14th, 2006, 14:50
NAXJA Member #1309
It's a one time deal on the sliders for now. Thanks for you interest.
Closed Thread
Rate This Thread:
HTML code is On
naxja discounts??? Justpunchit North Atlantic Chapter 19 February 1st, 2006 07:44
NAXJA NAC to join East Coast 4 Wheel Drive Assoc. NAXJA MEMBERS TAKE NOTE.. sidriptide North Atlantic Chapter 24 June 13th, 2005 06:38
ATTN!! NAXJA members, please visit members forum Goatman Sierra Chapter 2 June 27th, 2002 18:02
